i had a clogged nozzle i tryed to remove the nozzle and it broke now i cant seem to figure out how to get the broken piece out
Can you post a pic of what it looks like.
Your going to have tap the nozzle & try to back it out or replace the heat block.
Did you heat up the hotend when you tried to replace the nozzle…??
Yes I had it on 250 I had put in order in for. New hot end thank you for your help
