shin
September 25, 2023, 1:07pm
1
When I removed the magnet plate after printing and set it to AUTOHOME, the Z-axis did not stop and crashed!
The X-axis and Y-axis automatically stop, but the Z-axis doesn’t?
The Z-axis seems to be stopped by a magnetic sensor, but I want it to stop when it touches the end like the X-axis and Y-axis!
I don’t understand your need.
Do you want to print without plate ?
Squali
September 25, 2023, 4:27pm
3
It simply says that without the plate the detector no longer sees any metal part, the extruder continues to descend (which is logical)
Conclusion: do not do any home or adjustment without a PEI metal plate or other
In any case, it is impossible to print anything without a plate (glass or metal, even if in this case it’s mandatory in metal).
shin
September 25, 2023, 9:35pm
5
I understand that it is unnatural to do AUTOHOME after printing instead of before printing, and I never wanted to print without a plate.
The reason I want to do AUTOHOME after printing is to set the bed Y-axis to the neutral position after printing.
If the bed after printing is placed at the front, there is a risk of people or objects hitting it.
I will try to solve this problem by setting Cura’s End G-Code.
Lion
September 26, 2023, 1:11pm
6
Why not just auto home after you replace the plate…??
shin
September 26, 2023, 10:36pm
7
There is no special reason why I should do AUTOHOME only when I remove the plate.
