Autohome doesn't work
So I have updated the firmware because I had trouble connecting it to my pc. But now the autohome wont work and it just keeps pushing against the left x-axis and after ~4 seconds it shows “auto home failed please reset” but after resetting several times it still wont work. I’m clue less what I should do.
Please help and Thanks in advance.
Just reseted everything now it works just fine.
Tighten your X-Axis belt - the stop should be firm and instant…if it grinds while homing - the belts should be tightened or you should increase (increase sensitivity) the value in the config menu for senseless homing.
