Adc error
[extruder]
step_pin: extra_mcu:PA8
dir_pin: extra_mcu:PA9
enable_pin:!extra_mcu:PA11
rotation_distance: 6.5
microsteps: 16
full_steps_per_rotation: 200
nozzle_diameter: 0.400
filament_diameter: 1.75
max_extrude_only_distance: 150
max_extrude_cross_section: 60
heater_pin:extra_mcu:PB7
sensor_type:extruder_thermistor
pullup_resistor: 11500
sensor_pin: extra_mcu:PA5
min_temp: -0
max_temp: 310
max_power: 1.0
min_extrude_temp: 150
control : pid
pid_kp : 34.838
pid_ki : 4.976
pid_kd : 62.823
pressure_advance: 0.025
pressure_advance_smooth_time: 0.035
this happened out of nowhere. changed to a new hotend tried putting a new thermistor in and still got the same error? fried pcb board?
The max ships configured with a PT1000 sensor not a generic thermistor. If you change types you’ll have to update the configuration/
I had this issue out of nowhere then I put a chc xl hotend on only with the thermostat which is a pt1000 so I shouldn’t need to change any values ? Thanks cardoc
