the z motor will go up but not down the home command it just stays in the air i can make it go downwards but only by the distance it has gone up so if i go up 20mm then i can go down 20mm it always says zero i have emailed sovol for months now working on the printer i havent been able to fix it sovol has also given up
ive swaped ,the psu , the motherboard , reflashed it , replaced the cable , replaced the printhead and probe
im not sure how this is possible even to still be broken its a entirely new printer but whatever
yes it has a 5015 fan and a printed duct in white
yes it worked at one time and yes the red wire is the 5015 fan
i did try that once and yea it didnt work the printer but i can try again
Your printer has no idea where the bed is when you turn it on.
When you “Home Z” the printer slowly lowers until the proximity switch switches on, Then the software looks at the saved Z offset and assigns the spot where the switch turned on as Z = (0+offset). Once that is set the software will NOT go past Z = 0 even if that is actually 100 mm too high.
There is a led on the proximity switch. turn the printer on and raise and lower a metal plate (pancake spatula) under it. does the light turn off and on? Do you have wires run under (or near it)
Your printer “thinks” it is at Z=0 and won’t go lower.
The ONLY component on your machine that tells it where Z=0 actually is is the probe.
1% chance bad mainboard (false probe trigger)
1% chance bad firmware (probe signal mapped to the wrong pin)
98% chance your probe or probe wiring is faulty
With the connector plugged in measure volts between the points shown in the closeup. Does the value change when the proximity switch is triggered/untriggered?
You need to probe from the back side. If your probes are too fat colored paper clips can be useful. Unbend them and strip the color off each end. Straight pins (from a sewing kit) can be pushed through the insulated wire if all else fails.
Measure Volts, if your meter doesn’t autorange select a range suitable for 5v
100% this is your pinda probe thinks its already seeing the bed when it goes to home its not going down very far , so that is why its already at z 0 it wont go lower because that’s where it thinks the bed is in software it wont go lower the z=0 .
So how to fix , you need to diagnose the problem it either the signal from the pinda is not working or the signal from the pinda is not getting to the right pin on your main board, or less likely some odd setting for the signal pin in the firmware but if its stock firmware it should be correct , I have an oscilloscope so i would just trace the signal pin on the MCU board and see if its going high low with a bit of metal under the probe , but as you say you have replaced the pinda ? perhaps unnessory but eliminated it as the problem and the MCU have you checked the board behind the tool head a bad connector there or a cut track maybe stopping your signal getting to the main board that would be my guess.
How this works , when you home your printer the printer lowers the z , waits for the signal from the pinda to reset the height for the Z axis setting the 0 level , so seeing it not going down means it already thinks pinda probe is telling me we are on the bed ( when its not ) , this is why the logic of it going down further is not working it thinks its already on the bed when its homes because its getting a trigger from the pinda before it reaches the bed. i hope that makes sense .
This image shows you the pin connections to the daughter board , check that board very carefully for any broken tracks or bad connector connections , if you can test your probe signal in the marlin menu I would be doing that also , but its certainly related to your pinda signal as i can see your steppers are moving forward and reverse with no problem so its not a driver or stepper motor cable issue .
Cheers
SB
