Update for anyone else who may run into this issue with this printer. The bottom roller bearing can be adjusted with the wrench supplied with the printer while the hot end is assembled. just turn it either direction until it feels smooth. I would suggest disconnecting it from the belt for this but you really don’t have to if you don’t want to.
Related topics
| Topic | Replies | Views | Activity | |
| X axis is very crunchy all of a sudden | 15 | 231 | February 15, 2026 | |
| SV05 X and Y axis guide rail wheels | 3 | 474 | February 3, 2024 | |
| Brown dust on bottom rail and roller of the x axis | 11 | 154 | December 21, 2025 | |
| SV06 banging loudly when moving fast on Y axis | 15 | 983 | June 16, 2024 | |
| SV06 Ace Y axis problem (foam removed!) | 9 | 553 | April 14, 2026 |
