What is the process for setting up printer to use Borosilicate glass plate?
I have tried many things and no matter what, the print head crashes into the glass.
I setup the Home point with the PEI plate as being 10mm above the plate. Auto leveled everything, returned to home. Took off PEI plate and put on glass plate. Printer head returns to home automatically but, instead of being the height I set it for it crashes into the glass. How do setup the printer?
Good morning
A metal plate (PEI, PEO etc.) is essential, otherwise the inductive detector finds nothing and the head continues to descend. So glass plate to be avoided. Use the back of the PEI plate which is rather very smooth
1- Rude??? where did you see that? we must not have the same dictionary!
2- I print TPU, ASA, PLA and of course PETG on the smooth surface and it works very well! maybe you should try
