Using of the laser engraving kit possible
Hi!
Is it be possible to use one of your laser engraving kits on the sovol sv06 plus? This would be nice.
Greets
hi @Ulle70 Thank you for asking. Currently, this change can not be applied directly, you need to design the laser head mounting bracket and laser head wiring to enable it to connect to the cooling fan port on the motherboard.
