Would it be possible to connect the Sovol laser kit to the Sovol sv06plus with an adapter? If yes, what kind of Adapter, if no, how else would it work and what software changes do you have to make?
Yes it is with this mount. Make sure to connect the jumperwire on the mainboard when attaching the laser wire to K-FAN2.
Yes it is. I used this mount and some extra M3 screws to mount it. Follow all the other steps given in the manual, make sure no wires get in the way of the laser and you should be good. It worked for me.
Very interesting option by @flynindustries!
Another thought - Since I’ve added the SV06+ and SV07+ for my main prints, my SV06 sits idle most of the time. What about an option that replaces the extruder assembly completely? Has anyone experimented with positioning the Z access without the sensor?
Tim
