Underextrusion when accelerating after overhang corner
Hello, i have a very strange behavior related to extrusion.
Situation: I have a rectangular tower that is slightly bend to the side so one side has a slight overhang. I print with elegoo PLA+; 0.8mm nozzle; 0.4mm layer height; 110mm/s outer wall; slowdown for overhangs activated (I did not touch these settings at all)
Behavior: The printer prints the wall before the overhang and the overhang side much slower and then speeds up for the 2 walls after the overhang. And this acceleration causes massive under-extrusion and in the end leaves a hole in the print. It seems like it skips a part of the wall.
Already tried: 20% lower speed, setting pressure advance in steps of 0.005 up to 0.04, increase flow rate to 105%, increase temperature by 5° to 225
Question: I am aware that the bigger nozzle causes some irregularities in the normal walls, but this under-extrusion is very specific to the change in speed. does anyone have an idea what i can try?
Have you tuned pressure advance for this nozzle/filament/temperature? The other corner looks over extruded.
A square corner on an overhang is a difficult thing to print.
Have you checked for a loose extruder pin..??
I did a calibration for PA, Flow and Flow-Rate and managed to get better results with a higher Flow of 1.1 . The PA calibration did not look good at any setting.
What i also did was
  • cleaning the hotend again by pulling the Filament from the hotend at 60 degree and
  • cleaning the nozzle extra
  • lower the temperature to 220°
  • increase the speed for overhang to 60%
    Now the prints look much better.
and yes the extruder pin was tight. i even tried different levels of tightness :slight_smile:
Did you check the extruder / auxilliary extruder on slip, are you tried another nozzle?
When i have problems like that, off course try the settings PA, Flowrate, speed but after that i try to check some hardware.
Nozzle
Extruder
Fans
Filament
