Toplayer destroys print time after time
I get perfect results on all the layers except the last layer which destroys everthing. Is it possible to delete the top layer or copy the for last layer to the top layer?
Check your slicer settings.
Ironing may be enabled.
Otherwise, take a look at the end gcode in your slicer and check the last layer.
What slicer are you using?
You can change the fill pattern for top layers.
You can enable/disable ironing.
Most slicers will allow a different flow rate for top layers (see filament settings).
The top layer can have a speed of it’s own.
