Third party nozzle for SV06 ACE
Can confirm the CHT and E3D style nozzles fit with 0 issues
Been printing pretty much daily, testing flows, getting everything dialled in, 0 leaks so far, 0 issues with clogs, it’s been flawless.
Correct that the nozzle does sit a little bit higher up, due to it being shorter, but there is more than enough clearance between the shrouds and the bed.
If anyone is looking for nozzles for these; E3D fit absolutely fine.
Thanks! That’s what I wanted to hear.
BTW, what kind of max flow rates were you able to achieve with the CHT one?
Depends on filament
But elegoo rapid pla+ 210 peaked at 41mm3/s
I print it comfortably at 190, 27.5mm3/s
Gives very good overhangs with the stock cooling profile
Half a mm shorter than the nozzle from Sovol, but available in various diameters from Fysetc as a nozzle for the Creality K1. I installed a nozzle made of hardened steel with a diameter of 0.5 mm. I can’t find any problems.
I ordered 2x .4 nozzles to try them out. They also fit the SV06 Plus…which I also own. :grin:
I thought people had leaking issues with the K1 nozzles on SV08. Did you notice anything?
Here’s the reddit post describing the attempt to use K1 nozzles on the SV08. They say it worked fine for a few hours and then you’ll have molten filament coming out of the top.
I won’t test it for awhile, but if I have an issue…I’ll put it in the Plus.
As I said, the nozzle is 0.5mm shorter than the Sovol nozzle. This makes the nozzle 2mm longer than the Volcano nozzle. I can’t rule out problems! There are also minimal differences in the nozzles depending on the manufacturer. So far I haven’t noticed any problems. But I would like the manufacturers not to “invent” their own nozzle. That is very unpleasant.
Nozzles came in today…and yes I measured them, because why not :smile:
@Oliver was correct, as they are 0.5 shorter than the stock ACE nozzle.
But like I posted above,if I have any issues I will just use them in the SV06 Plus (23.4).
Humm…The SV06 Plus are longer also :upside_down_face:
Please let us know how your testing goes.
Old thread, but did you ever test them/confirm if they work or not?
Volcano nozzles were confirmed to work
