Our T300 printer stopped working - no filament extrusion. We disassembly the extruder and had to manually clear clogged filament which was all over the extruder compartment. After assembly we still cannot extrude filament - extruder is working but maybe hotend is clogged ?
What type of filament (PLA?, PETG? other?) and what temperatures have you been printing it with?
Hi
We are printing mostly with PLA (silk) - hotend 230, bed 65. Many printings on T300 went without problems - but once it get stuck we are unable to make it print again ![]()
Have you printed with filament that requires a higher temperature? If so, that could be stuck in the nozzle.
No - as I said we were using only PLA (different types) - when printer stuck we were using PLA from Creality - silk one.
Remove nozzle and hotend. I’m pretty sure they’ll be clogged.
