Svol1 pro keeps overriding abs temp setting?
WHEN I SELECT ABS 240 AND 70 SETTING AND SELECT THE PRINT FILE, i PRESS PRINT BUT WHEN IT STARTS TO PRINT THE MACHINE OVER RIDES THAT SETTING AND STARTS AT LOWER TEMPERATURES CAUSING IT NOT TO PRINT, AS EXTRUDER AND BED ARE NOT AT THE SELECTED ABS TEMPS . SO i HAVE TO STOP THE PRINT, RESET THE BED AND NOZZLE MANUALLY LET IT HEAT TO 240 AND 70. THEN SELECT THE FILE , HIT PRINT AND QUICKLY GO BACK TO THE MAIN SCREEN AND AGAIN MANUALLY RESET 240 AND 70 SO IT HAS NOT HAD A CHANCE TO COOL DOWN, THEN IT WILL PRINT WELL. WHAT A PAIN ANY WAY TO NOT GO THRU THIS ?
Hi Helijeff
The temperature needs to be setup in your slicer not on the printer screen.
My guess is that you are most likely using Cura.
Click on Material and then update the temperature setting as show below.
Once this is done, just re-slice a file with this setting and it will take care of the issue you described.
I will try that, thanks so much
