Continuing the discussion from Motherboard Buzzing Noise:
Mine has exactly seen the same until it failed. Replace was very easy but is failing again. Ideas?
What kind of bearing are you using? I’ve personally found that ball bearings tend to last longer when oriented vertically, while sleeve bearings do better horizontally.
