SV08 MAX Bed Heater overtemp
Just finished setting up my SV08 MAX and a few times the bed gets too hot, and the printer has done an emergency shutdown at 110C.
At first, I thought it was due to printing ASA with a desired temperature of 100C. However, I was printing PLA yesterday and pre-heated the bed to 65C, but the filament wanted 55C, so the heater controller was using 0% power to reduce the bed temp, but my power monitor said the printer was consuming 1200W and the bed temp was climbing over 72C. Even when I set the desired temp to 0C the heater kept running (though it said 0%). After I powered off the printer and restarted it, it worked normally.
Has anyone else had this problem? Is there a PID setting I can adjust to fix this, or to I need to ask support to send me a new bed heater board?
Thanks – Bob
Email Sovol at info@sovol3d.com
Explaining your issue, if you didn’t buy from Sovol you might have to deal with wherever you bought it from.
The bed heater on the Max is on line voltage. If the controller shorts to permanently on then the mcu is helpless to stop bed heating.
There is most likely a one shot thermal fuse next to the bed thermistor to kill it at some point (125 °C???) to prevent complete meltdown. Thermal fuses like that are not typically considered “user serviceable”.
Just for closure on this issue, I recalibrated the bed heater pid controller but I still got occasional runaways. SOVOL sent me a new bed heater control board, and I haven’t had a problem since.
--Bob
