You can reflash the chip directly with an EMMC to usb adapter, there’s links to one in this post: MKS board inside
Had to do this myself after I stupidly bricked my printer a second time and even harder than the first. As far as I’m concerned “update” = “kill printer”
On the bright side I’ve gotten so much practice bringing it back from the dead I’m no longer worried about it happening again.
Michael, 3pc, xtra gravy, xtra taters headed your way.
well call that a water valve cover level dum-dum
I had the motor mount all apart tryying to find an elegant way to get belt/bearing load paths aligned better. gave up, its to integrated, great mount, just missed the main param. never once checked the switch an inch away from my nose.
oem switch restored, well do a proper powerup when I get off the sim
Yes I know that issue well… change this, change that make it worse, scratch your head then realize it was the other, then try and back track… aw screw it start over again…. Lol
