Sv07 Moonraker freezes and disconnects. printer still finishes print
I am having an issue since installing Christian Vicks Klipper updates where moonraker will freeze half way into a print. Through orca the device screen will simply freeze. The Klipper screen will still work for a bit but eventually that will freeze too.
The only way to re-establish connection is to restart the printer after the print is done. Sometimes I even have to restart the firmware.
After installing the updates the printer worked fine for several weeks. Any idea what could be going wrong? Would Moonraker logs help ? My printer is in the same room as my Wifi
Comment out the CV “includes” and run a test print.
Ich habe das auch, nachdem hochfahren einmal rechts oben Mooraker neustarten dann ist er komplett hoch gefahren. CV Klipper habe ich auch.
