SV07 Double Sided PEI Plate
Hi Folks,
An important tip regarding the double sided PEI plate provided with the SV07 Plus - be sure to wash both sides with hand soap and warm water. This makes a massive difference in the way prints adhere to the surface.
Also, if you’re working during the day around the printer (so you can keep an eye on it), I recommend (through experience) that you allow the bed to heat soak to 90C for at least two 30 minute periods (non-printing). Also, my bed is around 8C off versus the thermistor reported temperature, so I set my bed around 5C warmer than the suggested temperature for the filament I’m using.
IIIDMax PLA+ is printing great in this printer. I got a really good looking 24 minute benchy at 200C nozzle and 65C bed.
Tim
About the somewhat random bed temperature: As my workroom’s temperature is down to 18 °C (the wife refuses to heat much more as it’s in the barn area :)) I had temperature differences of up to 10 °C.
So I’ve bought these bad boys: https://www.amazon.de/dp/B08CXZK8TY, unmounted the bed, glued one of the isolator sheets below it, mount, calibrate, … now, when I set the bed temperature to 65 degreen it’s between 65 (in the center) and 62 (at the borders).
Have to change all my temperature presets for filaments in Cura :wink:
