SV06 Filament Sensor not Recognized
I’m trying to add a filament runout sensor to my sv06, my issue is that it orgs not registering and that I also can’t find anywhere to enable/disable it in the control panel display. I have it connected directly to the mainboard and have 2 different sensors but neither works. I updated the firmware v2.0.0_A and that didn’t even help.
To see link for shared images Imgur: The magic of the Internet
Hello and Welcome.
You downloaded directly from Sovol? Weather to monitor the runout sensor is decided BEFORE the firmware is compiled. I believe that all official builds have it enabled.
Test your switch and wire. Check for 5V on the red+ Black- wires at the switch. If missing check at the mainboard plug. If good then check volts from white+ to black-. Should be near 5V with the switch arm extended and near 0 when you press the arm in. Verify the same at the mainboard. The white wire is the input to the MCU. If everything checks out let us know and we’ll circle back to firmware VS bad board possibilities.
Is there any possibility the plug is in backwards? The letters on the circuit board make me think I have the red and white wires reversed in test sequence I wrote.
The early SV06’s didn’t come with a filament sensor…I had to build a custom firmware for it.
Later they added firmware for a filament sensor.
I actually found a forked version on the Facebook group that resolved my issue thanks.
