SV06+ doesn't retract at end of print, and nozzle & bed stay hot
I have a SV06 and SV06 plus.
On the SV06, when the print is complete, it moves up in Z, and turns off the heat to the bed and nozzle.
However, on the SV06+, when the print is complete, the nozzle just stops on the part (doesn’t move up in Z) and keeps the nozzle temp and bed temp at full printing temp.
The problem is that this leaves a small “bump” on the part from the hot nozzle sitting on the part. Also, I don’t want the nozzle and bed to stay hot for hours, if the print is complete.
Should I do a firmware update? Or are there some lines of G codes that I should add to the end?
The SV06+ firmware is 1.1.4, marlin version 2.0.9.2
I am using Orcaslicer 2.3.0, using the configuration files from Orcaslicer | Sovol 3D Printer Wiki
I have only had this SV06+ for a few days, I purchased it used.
TIA
Check your “Machine end g-code” in Orca for both printers. I bet there is none for the SV06+
Note: don’t try to copy mine. Copy/paste from your SV06 profile.
The toolhead should move a little to the left & “Finish” should appear on the screen…
Once you hit Finish it will move the plate forward.
