Hello
I’m trying to print a model in dual mode. Head 1 is printing the model and head 2 is used to print the support.
The problem is that for every layer the head 2 is being heated up and moved to the center of the bed even if there is nothing in that layer to print.
This makes also the filament to be retracted every time until its totally removed from the head and then when its needed for print there is no filament available in the traction portion of the head.
I checked the G code and found this in every layer
T1
G92 E0
G92 E0
G1 Z{retraction_hop_height_after_extruder_switch} F12000
G1 E-3
G92 E0
M105
M109 S238
M104 T0 S215
M106 S127.5
G1 F600 Z3.5
;MESH:NONMESH
G0 F7200 X134.737 Y137.093 Z3.5
;TIME_ELAPSED:985.921565
;LAYER:15
G1 F600 Z3.7
G92 E0
G92 E0
G1 E-3
G92 E0
This shows what is happening. The head waits to the temp. Go to the center of the bed dont print anything retracts the filament and goes back to the home…
