Hey guys and gals,
I am having a major issue were neither fan turns on on extruder 1. I see nothing unplugged, no wired damage and I have tried flashing the firmware but no luck. The fans on extruder 2 turn on just fine. What can I do?
Hey guys and gals,
Hello Diddi,
in general, the etruder fans should run at 100% speed when preocessing gcodeM107 P0 S255 for left fan and M107 P1 S255 for the right fan. In case one fan is not working checking voltage using a multimeter could help to locate the problem: If the same voltage is present at both fan connectors you’ll need a replacement fan. In case of missing voltage you’ll need to check cables. Here you’ll find a documentation of all SV04 pins & connections on the motherboard & gantry breakout boards which should help to find the complete electrical connection down to the motherboard.
Good luck!
Björn
Typically, you should have a few fans as backups. Amazon usually sells them in 2, 4, 8 packs depending on the fan…JMO
Bom dia,
Meu problema é que a cabeça da esquerd(1) não aquece e a tela não sai da barra de progresso, a cabeça da direita(2) aquece.
já troquei o cartucho de aquecimento eo termistor e nada.
alguém tem alguma dica pra solucionar o probela?
já pensei em comprar a placa mãe, mas não consigo encontrar no brasil e nem em nenhum site da china.
