Anyone know how to fix thats artifacts. The belts are tensioned with a frequency of 110 hz, after that I calibrated the shapers, but the problem remains.
photo published on google drive:
There are other reasons that could explain the presence of artifacts, such as incorrect filament settings:
The temperature is not set correctly.
The maximum flowrate is set too high, which makes the slicer think that the filament can flow faster than it actually can.
The maximum flowrate is not calibrated correctly.
Moisture is present in the filament spool. Although this is unlikely for PLA, it can happen with matte or silky PLA.
I suggest adjusting these settings using the calibration functions in Orcaslicer.
temperature is correct and max flowrate is 2 times lower than this filament can do on my bambu lab, moisture cant be because i use different filament and one after drying. But thanks
Run the pressure advance calibration. You can set a global value in printer.cfg but the best way is to run it for each different filament and put it in the filament profile in your slicer.
More info at https://ellis3dp.com/Pressure_Linear_Advance_Tool/
After you get it dialed in reduce your “square_corner_velocity” in printer.cfg
