Sovol Zero Printer and Macro.cfg
Where can I get these two cfg?
I cleared the clog at the heatbreak but can’t print .
Error code 106
Thanks for your help
If you force a OTA “upgrade” the files should be reinstalled.
The files are also on Sovol’s github:
These are not up to date but should work
@cardoc are you saying that Sovol hasn’t posted on git what they are pushing out over the OTA updates?
If so, I’d appreciate somebody posting their stock config, as I neglected to make a backup copy before I started making changes
Sovol dosen’t update ANY of their repositories at github.
You can drill into the images posted on the wiki and extract files. I use 7zip and/or DiskGenius but there many others.
Here is the config folder extracted from SV08 zero_Update_Package-04-07-1.4.1.deb\data.tar.\home\sovol\printer_data\config\
zero1-4-1.zip (13.8 KB)
