Help needed: Sovol Zero stuck on “System Booting” after hotend maintenance
Hello everyone,
I’d like to explain the problem I’m having with my Sovol Zero. I hope someone can help me figure out what might have gone wrong or guide me through restoring the system.
One cold night here in Argentina, the filament got jammed. I tried to remove it using the usual procedure, but it was much more difficult than expected. After several attempts, I removed the cover that houses the fan and eventually removed the nozzle to clear the hotend.
So far, everything was fine. However, when I installed a new nozzle, I didn’t tighten it properly. When the filament started flowing, it leaked into the thermistor area, and I suspect the thermistor may have been damaged.
After that, I couldn’t remember where the case fan was originally connected, so I tried connecting it to several different unused connectors on the mainboard.
Following these attempts, the printer actually started working again. It began its automatic calibration and extruded filament normally. However, since it had disconnected from the Obico app on my phone, I decided to restart the machine.
After restarting, the printer got stuck on “System Booting” and has not been able to start up since.
Could anyone help me identify what might have been damaged? Is it possible that I connected the fan to the wrong port and caused a problem with the mainboard, or could the thermistor issue be related to the boot failure?
I would also appreciate any guidance on how to reset or restore the system and get the printer running again.
This is a used machine, and I don’t have a spare network cable or access to a computer to run diagnostic tools, so any advice I can follow directly on the printer would be especially helpful.
Thank you very much for your time and any help you can offer!
Here is the Tool Head setup.
If you still can’t fix your issue @cardoc is our Klipper go to.
A screen/monitor connected to the hdmi port will usually supply more info than the front screen does.
It is going to be difficult to repair your printer without a PC.
How does your printer connect to your local network?
Do you know your printer’s IP address? What happens if you type that IP into your web browser on your phone?
My assumption is your printer is “stuck” in the Armbian (Linux) boot process. Moonraker and Klippy don’t load until Armbian finishes booting. The first question is can you connect VIA SSH. I’ve never tried it from a phone but I’m sure there SSH apps for Android and iOS.
If SSH isn’t running on the printer your only route is to remove the EMMC module from the mainboard (NOT the toolhead) and reflash the complete OS/firmware package.
One trick, a HDMI display (even a TV) will show Armbian messages as the system boots up.
Is that image correct?
It’s different from the pdf on github
@ijsb20 The fan in the toolhead cover is to be connected to the “Model fan” at the lower right.
The only other unused 3-pin connector is the one next to the cooling fan (on the hotend heatsink), labeled “fan2” on the pcb. Connecting your fan to that one, should not do any harm at all.
My HDMI screen only shows a Sovol logotype and a rolling busy-icon. At least as long as there is no errors, which I haven’t seen yet. I can just hope it does…
The built in knob screen is not HDMI. It is a connected to the main MCU.
The HDMI port is connected to the host CPU that runs on Armbian.
The knob screen will not update until Armbian boots, Klippy starts and connects to the MCU and tells it what to display
Did you try the direct IP connection from a browser?
Did you try an SSH connection?
That wasn’t mainly ment for me, was it?
I did stow away the knob screen, and replaced it with Sovols HDMI screen on a printed bracket in its place.
I just wanted to point out that the HDMI screen doesn’t show any Armbian boot messages when the printer boots normally. Just the Sovol logo, until the Klipper screen comes live.
@pi.r Yes it was. Your original post didn’t mention any modifications so I assumed a knob screen.
And I also didn’t mention any problems with ssh or http connections (which I haven’t), hence my confusion.
Nevermind…
The hdmi screen doesn’t show all the output normally displayed by a booting *nix system, but it does provide more info than the front screen if there’s a boot issue. I had to utilise a hdmi screen when the final Zero I ordered had a mainboard fault, in order to diagnose the problem.
If your phone runs Android.
Obtain a EMMC Dongle. Amazon.com: Vacatga High Speed MKS EMMC USB3.0 Adapter MKS EMMC-Adapter V2 for EMMC Module andTF Memory Card Black PCB Black PCB : Electronics
Obtain a cable to equip your phone with a ASB A female port Amazon.com: USB-C to USB A Adapter 3.0 OTG Cable Hub Accessories for Pixel Compatible for Samsung Galaxy S21 S22 FE Ultra Z Flip LG iPhone15 Pro Max Plus iPad Pro Air Mini MacBook Type C Thunderbolt : Cell Phones & Accessories
Download the Zero Recovery image Image File - Google Drive
Use this:
To put the image onto the EMMC module off your mainboard. You may need another app to unzip the .img file.
I couldn’t find an iOS app that will write an bootable image to a USB device.
Extra credit. Insert your wifi info and disable the boot splash screen by editing files while the module is still attached to your phone.
Claud AI says:
Sovol Zero: set WiFi and show boot messages on HDMI (from an Android phone)
Written for image H616_2.3.3_debian_sovol-zero-1.4.7. Other versions are probably similar, but check that the files and lines named below exist before editing.
Both changes are text edits in the first (FAT) partition of the eMMC, so no Linux PC is needed.
What you need
  • The eMMC with the fresh image already written to it
  • A USB eMMC adapter and an Android phone with USB-C (OTG) support
  • A file manager (Files by Google, Material Files or X-plore)
  • A plain-text / code editor such as Acode or QuickEdit (see “Avoiding smart quotes” below)
Steps
  1. Plug the eMMC adapter into the phone and open it in the file manager. The FAT boot partition should appear as a USB drive.
  2. Do not format or erase anything. The phone may complain about a second, unreadable drive and offer to format it. That is the Linux root partition. Always decline.
  3. Open system.cfg in the text editor and change these two lines. Keep the straight double quotes:
    WIFI_SSID="YourNetworkName"
    WIFI_PASSWD="YourPassword"
  4. Open BoardEnv.txt and change:
    bootlogo=true
    to:
    bootlogo=false
  5. Save both files. Confirm they kept their names (no .txt or .bak added) and reopen them to confirm the edits saved. If the editor cannot save to USB storage, copy the file to the phone, edit it there, and copy it back over the original.
  6. Use the phone’s Eject / Unmount option for the drive before unplugging. Pulling it out while mounted can corrupt the FAT partition.
  7. Install the eMMC in the printer and power on.
Android keyboards sometimes replace " with curly quotes (“ ”), which breaks the config file.
  • Use a code-style editor (Acode, QuickEdit), not a notes app or word processor.
  • Turn off autocorrect, auto-capitalize and smart punctuation for the keyboard (on Samsung keyboards, look for “Smart typing”).
  • Paste the SSID and password if you can, rather than typing them.
  • Switch the editor to a monospace font so curly and straight quotes look different, and compare against the quotes on the lines you did not touch.
  • If the password contains ", $ or a backtick, put a backslash in front of that character, or avoid those characters.
  • Keep Unix (LF) line endings. Don’t use an editor that converts them.
What these settings do
  • system.cfg: WiFi is configured here, not through NetworkManager (its connections folder is empty on this image).
  • BoardEnv.txt: with bootlogo=true, the boot script adds bootsplash.bootfile=bootsplash.armbian to the kernel arguments, which shows the splash. Setting it to false removes that argument. console=display is already set in the same file, which sends kernel messages to the HDMI display. boot.scr reads BoardEnv.txt on every boot, so nothing needs to be recompiled.
  • Boot text on HDMI will disappear when KlipperScreen starts near the end of boot. That is normal.
  • If the display needs a specific resolution, uncomment and edit the extraargs=video=HDMI-A-1:... line in BoardEnv.txt.
Had a look earlier. That file’s in the /boot/ directory, so can be changed later on, too.
Display output was rotated 180 degrees when I tested it though, so that’s something which may need changing too, unless anyone’s good at reading upside-down text.
Escritura
Title: Help with Sovol Zero – MCU Error After Replacing the Mainboard
Hello everyone. I need some help fixing a problem with my Sovol Zero.
I had an issue with my printer and ended up replacing the original mainboard with a new one. Since then, the screen has failed to initialize properly, and the printer is no longer working.
I can access the web interface (Mainsail/Fluidd), but Klipper displays MCU communication errors.
When checking the system information, I found the following firmware versions:
Main MCU: 14d7b18-dirty-20250210_015142-SPI-XI
Extruder MCU: cc8afd8-dirty-20250305_010730-SPI-XI
There is also a command format mismatch error related to ldc1612_setup_home.
I have already tried restarting Klipper and the firmware through the web interface, but the problem persists.
From what I understand, there may be a compatibility issue between the firmware on the boards and the installed version of Klipper.
Could someone please help me with the following?
Obtain the correct firmware files for both the mainboard and the extruder MCU.
Find out how to update or reflash both controllers.
Learn the correct procedure for doing this via USB or MicroSD card, if supported.
I currently don’t have access to a working SSH terminal to perform the update directly.
I would really appreciate any guidance, firmware files, or tutorials you could share. I want to get my printer working again without risking further damage.
Thank you very much for your help!
Mention the original hardware fault
Add the exact error message
Clarify the replacement board details
Go in via Fluid or Mainsail and download klippy.log from the printer. Zip it and attach it to your next post.
Continuando la discusión desde Help needed: Sovol Zero stuck on “System Booting” after hotend maintenance:
klippy.log.zip (4,1 KB)
Swap the EMMC. Fit the one from your original board onto the new board, & then let it do the OTA update.
Escritura
Hello everyone,
I believe there may be a misunderstanding regarding the hardware replacement in my Sovol Zero.
I did not replace the main motherboard. I replaced only the toolhead PCB (the circuit board located in the printhead). The original main motherboard is still installed in the printer.
Therefore, the eMMC memory mentioned in the previous replies does not correspond to the board I replaced. The toolhead PCB is a separate board responsible for controlling the printhead components, and it is not the main Linux system board that contains the eMMC storage.
For this reason, transferring the eMMC from the original motherboard to a replacement motherboard is not applicable to my situation, since the main motherboard has never been replaced.
My printer remains stuck on “System Booting,” and I have also encountered MCU communication and firmware-related issues.
Could someone please help me identify the correct diagnostic procedure for the toolhead PCB replacement, particularly whether the new toolhead board requires firmware flashing, MCU firmware synchronization, or any specific configuration to work correctly with the original mainboard?
Thank you for your time and assistance.
Your log file indicates a heavily modified configuration. Did you reuse the original EMMC? Have you made any changes to printer.cfg?
Sovol changes Klipper’s logging function so I can’t see your runtime configuration.
Does the toolhead have Sovol’s original eddy sensor?
You replaced the board on the printhead or the one under the cover on the back of the printer?
Hello, thank you for your reply.
To clarify, I did not replace the main motherboard or the original eMMC. The only hardware component I replaced was the toolhead PCB. The original mainboard and its eMMC are still installed.
I also kept the original Sovol Eddy sensor; it was not replaced.
Regarding printer.cfg, I have not intentionally modified its configuration. If the logs indicate significant changes, could you please help me identify which settings appear to be different?
The printer remains stuck on “System Booting,” and I would appreciate your guidance on diagnosing the toolhead PCB firmware and MCU communication.
Thank you for your help.
