Sovol Zero Magnetic Buildplate Holder
For my forum friends.
Very nice work. Thank you!
I bought an inexpensive PEI build plate on Amazon but it’s only 150x150 mm so it’s a bit small, and it doesn’t have the alignment tab in the back. It works but it doesn’t fit well or easily. I should buy a spare or two from Sovol but I guess I’m waiting for them to be on Amazon to facilitate ordering, and maybe they’ll be a bit less expensive. On the plus side, with the Zero making a bed mesh and probing the Z offset before each print, different build plate thicknesses shouldn’t be a problem.
The plate is 162 mm²
Nice touch. How often do you switch out build plates?
Right now I’m mostly using the Blue plate.
I will normally switch a plate when a model sticks too well & I need to keep printing…
…or I need to clean the plate.
The Glacier is good for all filaments.
If I didn’t cut it down I would have bought another Sovol plate, for the same reasons posted above.
