Hello!
i want to introduce you my Sovol SV08 Single Door Mod!
It is plug and play, so you can use the original holes. Also it is magnetic, so the door is hold closed.
I would be very happy if you like my model ![]()
Hello!
I don’t own the SV08 but could you explain the advantages of this door comparatively to the stock doors ?
Hey, i dont like to open two doors to access the printer
Yes, I understand but, to keep the heat with, for example, special filaments, it is often better to only partially open the printer.
