I need advice. I have a Sovol sv06. and I would like to print on a glass substrate, but when I calibrate it, it hits the substrate and I don’t know what to do. I’ve tried everything. The glass substrate is 6 mm thick. What will I need to change so I can print on glass?
I don’t know what you call substrate.
If it’s the bed, you can’t use such a plate with this printer. Because of the magnetic probe, the plate must be metallic.
