Sovol SV06 ACE display cable
How is this cable connector on Sovol SV06 ACE called? Or where to get extension cable for the display? I want to add printer into enclosure and relocate the display.
Thanks
Send an email to Sovol at info@sovol3d.com
It looks to be proprietary to Sovol. The ends are each generic but I’ve never seen the 2 on 1 cable.
You may be able to locate an extension for one end or the other.
JXHMP3A02-09013-g FFC屏幕排线.pdf (205.0 KB)
JXHMP3A02-09013-g FFC屏幕排线 translate_.pdf (146.3 KB)
You could always run MobileRaker on an android tablet and mount that to the enclosure.
What did you do in the end? I’m logging at doing the same, and the display means needing almost an extra 10cm of width.
