Display modification
After checking out the GitHub repository, I noticed that the printer’s screen connects with MKSClient, and I haven’t seen any code related to the screen to add functionalities (like filament change, for example), modify them (like adding more materials for preheating), or change its appearance.
In case you don’t release the code for the screen, do you know if there’s any way to reverse engineer it to make it work?
Can KlipperScreen be used with the current screen?
Thanks :slight_smile:
From what I understand, the screen software is proprietary from a 3rd party and Sovol cannot release it.
We have already discussed this issue in connection with the LED on the camera. The display software blocks the port. We have not found a solution. To give Sovol a few arguments, we have created a list. Just add the problem. Thank you!
