I downloaded the latest slicer from the sovol website and it has profiles for Marlin and klipper.
The marlin profile worked just fine, but the print quality was not good, due to the vibration caused by the high speeds.
I tried clamping the frame down to ease the vibrations but this only made things worse,
So, I went the other way and designed these feet to absorb the vibrations and it worked,
Printed out this Benchy in 35mins with marlin running at 200mm/s…
Can/will you post stl for the feet…??
