I have the sovol so-2 with 10W laser and LightBurn as control software.
Since the beginning, it comes again and again to disturbances that the laser simply breaks off during the cut and no longer continues. Depending on the power it stops after a few seconds or minutes, but in the debug console there is no output about an error or alarm.
In other forums you can often read that the chips on the motherboard can get too warm and it comes to a reset of the entire control unit. The installation of additional heat sinks unfortunately did not have the desired result.
Also the use of different USB cables to exclude a cable break or similar did not lead to any result.
Is this problem known and is there a solution or anything I can check?
