Just curious what most people here run for their general profiles in terms of the slicer itself and the print settings for daily run-of-the-mill jobs.
I run Cura with pretty much the default SV06 profile provided by Sovol with a few exceptions. I use a 0.6mm nozzle at 0.2mm layer height with the speed turned up to 80mm/s and the PLA temp up to 205. I usually print without z-hop enabled since it causes horrible stringing. All other retraction settings are default. I have fairly good results however every now and then certain prints just look flat out bad. I usually notice this when I try to print at 0.24 or 0.28mm layer height.
