I recently bought a new printer and relocated my SV06ACE to work.
My workplace has both a username and password requirement to log into the WiFi - so I’m having a little trouble getting connected.
It’s not an SSID issue - the SSIDs are visible and available.
If y’all have any further advice, I’d appreciate it.
In lieu of that, I’m trying to transfer files via USB to the printer. I’m using a Lexar 64Gb flash drive (formatted exFAT) to pass GCodes from my slicer to the printer, but the printer is not detecting the drive or the files. I think I’m missing a directory, but I cannot find hide nor hair of what to call it. Can someone let me know what I might need to do?
I experience the same behaviour. Even when entering the correct password, logging on to my work’s wireless network requires both a username and a password to be entered. Without both, I cannot connect.
The Sovol network security “features” top out at WPA2. Your work network likely has higher requirements.
Is the printer in use for activities in support of your job? If so ask work IT dept. to provide a linux supported USB to WiFi dongle compatible with their WiFi. A USB to ethernet adapter could also work if a wired network port is nearby.
Configuring a USB WiFi adapter will most likely need a temporary serial connection to SSH in and set it up.
