PETG on the SOVOL SV08 issues
I had an issue with the Nozzle being far too low using the SOVOL SV08 Ocra Slicer Settings
PLA prints GREAT, no issues.
So I tried coping the PLA settings as PETG files in Orca Slicers with changes to reducing the speed and increasing the temperatures
BUT when I do this Slice then Upload for Printing the file still suggests that it is PLA in the filename
If I select PETG files in Orca Slicer it uploads and Prints with the PETG in the filename; but this has the Nozzle fare too low: DAMAGE the Build plate caused
Any help will be appreciated
About petg printing, we can send a new nozzle to you. You can send an email to info@sovol3d.com
It seems to be Orca Slicer
PLA 3D Prints without any issues; Why should PLA be OK but PETG print too low?
Farmwear supplied
2.3.2
2024-4-15
but if I ask for PETG, same file it prints with the Nozzle scrapping the Texture off the build plate
There is a newer firmware and also some updated slicer settings available on SV08 | Sovol 3D Printer Wiki
Tanking You;
I have Sovol_Update_Package 2.3.3 6-20.deb
so have :-
Firmware
2.3.2
2024-4-15
OcraSlicer using 2.1.1
Will have a look at: Profiles PLA/TPU/ABS/PETG 0.2/0.6/0.8mm - Google Drive
Thanking you once again :slight_smile:
Unsure where to put any files from the Wiki
C:\Users\USERID\AppData\Roaming\OrcaSlicer ???
Sovol
and
Sovol.json
A quick google shows :
Default presets are in C:\Users%USERNAME%\AppData\Roaming\OrcaSlicer\system as .json files
User presets are in C:\Users%USERNAME%\AppData\Roaming\OrcaSlicer\user\ (some number) \ as .json files
Thanking you :blush:
I think there two lots of JSON files a group under the Sovol directory and others more direct.
So which is the correct json files or do I just put the whole Sovol directory in.
Cura slicer was about 24 times easier
Not just this but everything
One example why does ocra slicer suggest there is an import printer setting type files like these, then they want to find the correct directory then copy the correct file there
orcaslicer has an import function in the menu, you can add the folder with profiles and the json file via that route
Import function in the menu, does NOT work for me???
Take a look at this video from around 9 minutes. This describes the process for the SV07
