Nozzle clog detected! Temporary-bypass
In case someone encounter the same issue as me you can bypass the Nozzle clog detected! you can temporary bypass by using this command:
SET_GCODE_VARIABLE MACRO=variables VARIABLE=is_manual_feeding VALUE=True
Hope you dont have to use it. but I leav it there maybe someone will need it.
will it be effective if I enter it during a print process?
or at the false clogging report caused pause?
IT works while printing!
