I believe this is valid for both Sovol Zero and SV08 MAX (same tool-head?).
It appears that someone at Sovol have introduced an “unconventional improvement” of the heater-block - without any notice… anywhere…
There is now a small grub screw on the right side of the heater-block, that goes straight into the treads of the nozzle, and locks it in position.
They also introduced some thread-locking-goo in there, to be really really sure that the nozzle shouldn’t come loose - ever…
The idea of a screw jamming straight in to the threads of the nozzle isn’t great, in my opinion. It might be OK with a hardened steel nozzle, but a nickel-plated copper nozzle wouldn’t like that…
I didn’t notice the grub screw, and this is how my nozzle looks like after removing without loosening it on my brand new Zero:
It was a bit sneaky, as the screw is facing to the side, so it’s not obvious that you notice it, before you put your wrench over there and cover it. I didn’t…
At first I thought I ruined the heater-block as well, but it turned out that I could clear the debris from the nozzle out of the block threads, and it appears to be OK. Good knows what would have happened if the nozzle was of hardened steel..!
This is how the heater-block looks like on my printer, which is one of the very last few sold on sovol.eu:
(grub screw removed)
Looking at new heater-blocks among Sovols accessories, and comparing to imagery form numerous videos I’ve seen, this seems to be a new version of a new version. The first version, seen on most youtube videos, don’t have a copper cylinder on the heat-break tube, like this one has, shown at Sovols accessories: Nozzle and Heater Block Kit for Sovol Zero.
And there are no grub screw! So clearly the have come up with a third version.
The first style, without copper cylinder, doesn’t seem to be available at Sovol (if it ever was used in production?)
The CAD-drawings on github isn’t updated at all (still without copper cylinder).
I did order a complete toolhead (Extruder Kit) as a spare part to my printer (I knew the Zero is discontinued). That heater-block allso has a grub screw.
That spare part kind of saved my day, as I could easily swap the hotend on my printer and go on - I thougth… But then I doubted the nozzle temperature calibration with the new hotend. It seemed to hot. It wasn’t but led me to an interesting journey into the PT1000 configuration and calibration of the Zero. - A subjekt for another thread…
