Hi there, I recently bought a SV04. I have a problem, first everything worked fine, but when I try to print with my left extruder/printhead I get the message: Click Yes to heat andchange filament or No to stop print
The right extruder/printhead works fine, so I think there is a problem with my left filament run out sensor. I hear the relais clicking when I put filament in the runout sensor, so the relais switch is probably working.
Can you help me with this problem?
I disassembled the runout detector, and assembled it again, and now it works??
Maybe an electronic hick-up?
But it works, thanks for your quick reply
MarioReget
But if it plays up again you can just unplug the run-out sensor and the Printer will work fine without it until you can fix it or get a Replacement switch-.
