so i am doing a 2 model print that are mademto fit together. in cura they look perfect but when i print them the right extruder causes it to overlap what is done from the left extruder. any ideas how to fix this? the models are grouped together and look perfect in cura.
Does that overlap also happen when printing the “Extruder Offset Calibration” models that came on the SD-card with your SV04? In this case you want to follow the “Sv04 Dual Nozzle offset Setting Tutorial” & adjust the dual nozzle offset calibration.
