This is driving me up the wall, printer and PLA filament calibrated through all of Orca tests, but there is an artifact that shows up every time oriented toward the Z1 (front left) rail. It is a repeating artifact mostly vertical, that ruins all prints. It is not slicer-related, because I’ve printed different models, changed the seam placement, put the seam on random, etc. and has no effect, always occurs facing Z1 rail. Must be mechanical? But it’s a brand new unit. I really don’t want to have to send it back, I need the printer soon. Things I’ve tried are below:
No problem, the Z1 is the front (closest to user and front display) to the left of that display. So facing the printer, the front, left rail and belt (not screw rods). This is important there are not 4 rods, they are four z belts.
Don’t forger to manually set your max acceleration (X and Y) in Both your printer.cfg AND your slicer. Note: I set accelerations to 75% of the recommended values.
