Manta M8P V2 conversion for Sv08
So my mainboard emmc died so I switched to an SC card. Then the Z1 motor driver failed.
This prompted me to install a Manta M8P V2 on the machine (what a pain that was). There was wiring extensions, countless hours of trying to map which wire goes where, etc… However, I got it up and running and everything works except I am getting what I believe is a strange result on input shaping. Typically input shaping would start with long movements and then get tighter and tighter. This setup only does the movements around 50mm and never gets to that tight buzzing type test. Any ideas where i can start to dig into this problem?
Are you running mainline Klipper?
If so I’d reach out at General Discussion - Klipper
What are you using for a klipper host (Pi)?
I am using mainline Klipper and I am using a CB1 module for right now but plan to move to an HP EliteDesk 800 G6 soon (this design is so I can run my other printers from the same machine)…
I will repost in the other forum. thanks for the advice.
With the hardware change your SV08 is a Voron 2.4.
Lots of help available form MANY sources.
