After following instructions and watching a few videos, I put together my Sovol SV06 Ace Plus. On my first print, I encountered a very loud, fast clicking when the extruder moved across its mount. This has happened when it was printing, and when it was just resetting itself - without filament. I took apart the extruder, all looked fine to. my novice eye. I checked the belts, and the filament tension screw. I might not have leveled it correctly and will work on that next. Any other ideas as to what is causing this? I’ve tried researching online, but haven’t had luck finding what I need specific to this printer model.
lay the printer on its side and check for a foam block underneath the bed.
Yep, that was it - thank you! They should make those blocks bright yellow.
Once a week a new ace owner has the same issue on here. God knows how many support cases go straight to Sovol.
