My lights are flickering when printing.
I don’t have an option to plug it in diferent circuit, also no option to change lights.
Found this description on Lights Flickering | Voron Documentation
Recomended is changing pwm_cycle_time under [heater_bed] pwm_cycle_time: 0.02674 # 37.4Hz
or pwm_cycle_time: 0.02506 # 39.9Hz
for 50Hz.
This line is not included on SV08 printer.cfg.
Can I just add this???
Did anyone tried?
You mean the actual lights in your room/house? Mine do that too when the printer is running, or should I say attempting to run!
I will try the solution you’ve linked to.
Just another joy suppled by this terrible printer, it seems. I’ve had the thing for 5 days now and it’s been consistently useless and frustrating, I’m afraid.
Regards,
T
Hi Tim. I tried many diferent settings a day ago and settled on pwm_cycle_time: 0.02506 # 39.9Hz
Set of lights on corridor is better now, printing room lights are still flickering. I guess led light for 9 euro was not a good idea…
I might try to change lights, but it is tolerable now.
I got mine SV08 back in November, needed two days to setup everything and had no problems since. Just works. Except for matte PLA doesn’t like fast printing and doesn’t stick well. BTW, i changed nozzle for Microswiss flowtech cht 0.8, before even turning it on. So I don’t know how this works with original nozzle. I found gerGO PRINT3D channel on you tube very useful. Also macros this guys make are very convenient.
Good luck.
