I installed a significant upgrade to the LED lighting in my Zero yesterday.
I bought the supplies on Amazon:
8 mm wide 24 VDC LED light strip
22 AWG hookup wire, although all black wiring would look better inside the Zero
I 3D printed some mounts for the 15 mm T slot aluminum extrusions on the top of the Zero. Here is a short test print.
The full length mount is 80 mm long, printed vertically on the Zero from TPU-LW, but TPU should work, and more rigid filaments may work with some minor tweaks to the geometry and/or slicer settings. I used two of these mounts on the top front, two on the left side (facing the printer), two in the back, and one on the right side, behind the weak stock LED strip. Here is the full length LED mount shown on top of the Zero as a demonstration.
Unplug the Zero before wiring. Power is supplied to the LED strip on the right front top, where the original LED also receives power, and the LED strip is routed across the front, down the left, across the back and up the back of the right side. Approximately 7 W of LED lighting is added to the Zero.
The wire is routed parallel to the stock LED power wire on the inside of the right front corner. The camera is removed to route the cable behind it and then reinstalled.
The bottom cover is removed and the wire is routed along the front and up the side next to the power supply. The black wire is terminated in a spade lug connector and connected to the spare -V terminal on the 24 VDC power supply. The red wire is connected to a 1 A fuse and then connected to the +V terminal. I took the opportunity to finish tightening the other screw terminals on the power supply. Each got 1/4 to 1/2 of a turn.
Great care should be taken to ensure that the wiring cannot contact the Z axis motion system. Keep the wiring as far as possible from the timing belt and pulleys, and use wire ties to secure it safely away from all moving parts.
There is a significant increase in lighting inside the Zero.
Contrast the brightness of the added LED lighting around the entire perimeter to the short piece of stock LED strip.
The camera image when monitoring the print in Mainsail improved greatly from the improved lighting.
Here are the files for the 3D printed TPU-LW LED strip holder for the Zero.
LEDStripHolder.3mf (22.3 KB)
Sovol Zero-LEDStripHolder-TPU-LW-00h46m-SOVOL_ZERO_ONLY.gcode (2.4 MB)
LEDStripHolder.stl (4.4 KB)
LEDStripHolder.FCStd (37.9 KB)
Here it is on Printables and Sovol’s PrintsDepot:
