Klipper-What do you put in printer.cfg file?
I am using octoprint with klipper on my sv06 and it is giving me a ton of warnings related to the printer.cfg file and I cant really figure out what exactly I’m supposed to put in the file, I’ve tried different things and they haven’t worked. is there anything I can just copy paste and put in there?
Thank you so much for buying from Sovol, and I apologize for all the inconvenience.
Did you already send an email to info@sovol3d.com? If not, please send the above situation with videos and pictures and your order number, and we will check with the engineers asap.
Hi @Chief , I just saw your post, I’m hoping that you got things going already. But if you haven’t, here is an example of my printer.cfg for the SV06. Do not to just copy and paste, my setup will be different from yours. But this will give you a general idea of what you need:
[mcu]
NOTE Obtain definition by “ls -l /dev/serial/by-path/” or “ls -l /dev/serial/by-id/”
serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 200
max_accel: 3000
max_z_velocity: 15
max_z_accel: 45
square_corner_velocity: 8.0
X/Y/Z Stepper Settings
[stepper_x]
step_pin: PC2
dir_pin: !PB9
enable_pin: !PC3
microsteps: 128
;microsteps: 16
rotation_distance: 40
endstop_pin: tmc2209_stepper_x:virtual_endstop
position_endstop: 0
position_max: 223 # NOTE You can adjust this if you have more room
homing_speed: 40
homing_retract_dist: 0
[tmc2209 stepper_x]
uart_pin: PC1
run_current: 0.85 ;1.0
stealthchop_threshold: 0
interpolate: False
sense_resistor: 0.150
uart_address: 3
driver_SGTHRS: 81
diag_pin: PA5
[stepper_y]
step_pin: PB8
dir_pin: !PB7
enable_pin: !PC3
microsteps: 128
;microsteps: 16
endstop_pin: tmc2209_stepper_y:virtual_endstop
position_endstop: 0
homing_speed: 40
[tmc2209 stepper_y]
uart_pin: PC0
interpolate: False
uart_address: 3
driver_SGTHRS: 81
diag_pin: PA6
[stepper_z]
step_pin: PB6
dir_pin: PB5
enable_pin: !PC3
microsteps: 128
;microsteps: 16
endstop_pin: probe:z_virtual_endstop
position_min: -4
position_max: 258 # NOTE You can adjust this if you have more room
homing_speed: 5
[tmc2209 stepper_z]
uart_pin: PA15
interpolate: False
uart_address: 3
diag_pin: PA7
Extruder
[extruder]
step_pin: PB4
dir_pin: !PB3
enable_pin: !PC3
microsteps: 16
rotation_distance: 4.65 # NOTE Calibrate e-steps Rotation distance - Klipper documentation, https://github.com/bassamanator/everything-sovol-sv06/blob/main/howto.md#calibrate-esteps
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
#control: pid
#pid_kd: 86.991
#pid_kp: 21.479
#pid_ki: 1.326
min_temp: 0
max_temp: 300
max_extrude_only_distance: 150.0
max_extrude_cross_section: 5 # NOTE Needed for KAMP purge
[tmc2209 extruder]
uart_pin: PC14
run_current: 0.550
interpolate: False
uart_address: 3
Bed Heater
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
#control: pid
#pid_kp: 64.440
#pid_ki: 0.773
#pid_kd: 1343.571
min_temp: 0
max_temp: 110
Probe Related
[probe]
pin: PB1
x_offset: 27
y_offset: -20
#z_offset: 0
samples: 3
samples_result: median
samples_tolerance: 0.01
samples_tolerance_retries: 5
[safe_z_home]
home_xy_position: 84.50, 135 # NOTE The probe is at the center of the bed.
speed: 100.0
z_hop: 10
z_hop_speed: 15
[bed_mesh]
speed: 175
mesh_min: 27, 6 # probe as close to origin as possible while remaining fully on the bed
mesh_max: 222, 203 # (x.position_max - 1), (y.position_max - abs(y_offset)) ; probe as far as possible from the origin while remaining fully on the bed
probe_count: 5,5
algorithm: bicubic
fade_start: 1
fade_end: 10
fade_target: 0
[axis_twist_compensation]
calibrate_start_x: 27 # probe x coor at furthest left ; abs(x_offset)
calibrate_end_x: 195 # probe x coor at furthest right ; (x.position_max - abs(x_offset) - 1)
calibrate_y: 115
Fans
[fan]
pin: PA0
Misc
[display]
lcd_type: st7920
cs_pin: PB12
sclk_pin: PB13
sid_pin: PB15
encoder_pins: ^PB14, ^PB10
click_pin: ^!PB2
[bed_screws]
screw1_name: front left
screw1: 26.5, 31
screw2_name: front right
screw2: 196.75, 31
screw3_name: back right
screw3: 196.75, 201
screw4_name: back left
screw4: 26.5, 201
[screws_tilt_adjust]
screw1_name: center
screw1: 84.50, 135
screw2_name: front left
screw2: 0, 51
screw3_name: front right
screw3: 169.75, 51
screw4_name: back right
screw4: 169.75, 221
screw5_name: back left
screw5: 0, 221
horizontal_move_z: 10
screw_thread: CCW-M4
[output_pin beeper]
pin: PC6
value: 0
shutdown_value: 0
pwm: True
cycle_time: 0.0005 ; Default beeper tone in kHz. 1 / 0.0005 = 2000Hz (2kHz)
[filament_switch_sensor filament_sensor]
switch_pin: !PA4 # “Pulled-high”
pause_on_runout: True
insert_gcode:
M117 Insert Detected
{ action_respond_info(“Insert Detected”) }
runout_gcode:
M117 Runout Detected
{ action_respond_info(“Runout Detected”) }
CONDITIONAL_BEEP i=3 dur=300 freq=400
