Issues since CURA upgrade
Hello, have had issues since upgrading to latest CURA. Printer begins correctly, X,Y,Z homes, autolevels, then homes again 2 or 3 times then locks up at X,Y origin. I have re-written the Start G-Code per both old and new instructions, still same issue. Have also un-installed latest CURA and re-installed 4.7 with both start G-Code settings. HELP!
Start G-Code:
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
G29 ;
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
I’m not 100% sure whether this is what you’re facing, but I’ve experienced similar sounding lock ups when I went to a different board, and compiled firmware for it.
It ended up being BLTouch related, and the stock firmware will retry levelling three times before it gives up, if I’m remembering correctly.
Can you double check that the BLtouch wiring is in correctly, and you don’t have a wildly unlevel bed from the beginning (as in, go do the corner levelling).
Good luck!
Edit: Oh man. I just realised how old this post is. Sorry!!! Decided deleting was not helpful, so keeping my shame up :slight_smile:
Hello reildeal
Are you using a touch screen? Solution two can verify
1, operation initialization, restore factory settings.
2, modify the start gcode.
G28 ; Home
G29 ;
Change to G28 ;Home
M420 S1 ;
Require automatic leveling before selecting a file to print, so that you do not need to execute G29 again for automatic leveling if you select a file to print
Thank you
Best regards
Sovol team
