Haven’t worked on my SV03 in a couple of months so I tried to print on it and I get a noise from the bed moving then the hot end moves to the right and make a loud noise then I have ti cut the machine off. What is causing this problem? I thought a bad sliced file so I used one that worked with the machine before and it did the same thing. I cut it off and back in then sent the hot end to home and again the same thing, bed naked noise moving in the Y axis and hot end moves to the right and makes noise and I just cut it off.
I got the machine last year and haven’t done a lot of printing on it.
