Issue Description
Hello everyone,
I’m experiencing an issue with my Sovol SV06 Ace, and I hope someone can help me find a solution.
When I turn on the printer, I repeatedly get the following error in the Klipper log:
🚨 Invalid lis2dw id (got 4 vs 44).
This is generally indicative of connection problems
(e.g. faulty wiring) or a faulty lis2dw chip.
Additionally, I see this CHOPCONF message:
⚙️ CHOPCONF: 340004c1 toff=1 hstrt=4 hend=9 mres=4(16usteps) intpol=1 dedge=1
What I’ve Checked So Far
LIS2DW Accelerometer Connections – I have checked the wiring and everything seems properly connected.
Firmware & Configuration – No recent major changes to firmware, but I am unsure if this could be a configuration issue.
Power Supply – The board appears to be receiving power correctly.
Possible Causes
Faulty wiring or loose connection – A bad cable or loose connector could be causing communication failures.
Incorrect I2C/SPI configuration – The wrong pin assignment might be set in printer.cfg.
Defective LIS2DW chip – If everything else checks out, the accelerometer itself may be faulty.
Firmware update issue – If the problem appeared after a Klipper update, it could be a software-related bug.
Seeking Help
Has anyone encountered this issue before or knows how to fix it? Any help would be greatly appreciated! ![]()
Thanks in advance!
