How to take off build plate?
The instructions do not clarify how to take off the build plate and if it did, it would be so much easier taking my prints. Whenever I try to take it off (By lifting it up and out) I feel a lot of resistance and I don’t want to break my new printer.
Most of the time, you don’t have to remove the plate, just lift up/flex one of the 2 front corners & the print will pop off.
On big prints, that take up most of the plate…is where the issue can be…because you can’t bend/flex the plate. It can sometimes be a real pain to remove the print. But, it can also happen to smaller printers…I’ve had more issues trying to remove the plate on my A1 mini than any printer I own.
Anyway, the magnet on the bed holds the plate down. If you can’t flex it, it’s harder to remove the print.
